585,743 active members*
5,056 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics centurion V program?
Results 1 to 10 of 10
    Dec 2007
    118
    Angry Milltronics centurion V program?
    Hi guys, I have a milltronics with a centurion V control, here is my problem, when I punch in a nice short program like just a drill hole, I have to press pause and resume and cycle start and flood make it go step by step, there is no error just stops after every command, also I noticed that a g54 command will make go bunkers, can any of you guys help please, the program will not run full auto. I am using bobcad/cam with fanuc o post processor. I also noticed the cancel star comes on...
    Feb 2011
    sounds like it is in single block mode.
    Oct 2008
    427
    Could you include a copy of the code in a post?
    It will help to see the actual commands the control is trying to process.
    Dec 2007
    118
    Ok, frist pic is from machine is running and program is hung up, second is pic of program, when I press the block button it turnes dark and I can't get the machine to move even with pause and resume...???? All three program stopping buttons are light in color when frist rebooting and running.
    http://i1238.photobucket.com/albums/...s/IMG_2332.jpg
    http://i1238.photobucket.com/albums/...s/IMG_2331.jpg
    Dec 2005
    61
    If you hit display error what is your following error wen the machine stops?
    The problem maybe the axis is not in position.
    Oct 2008
    427
    Is the A axis connected and working?
    If not, the axis may be drifting and the control is waiting for it to get back to position.
    As Mark suggests, look at the following error display to check. You may also change the Following Error parameter to a 0 (zero) to force the control to not care if it drifts.
    Dec 2007
    118
    I do not follow, there is no error, timer is still running but machine will not move to next step till I press f9 pause then resume then it will go to next step, ???
    Dec 2007
    118
    Ok guys, I unpluged the A axis and now the machine is working, how do I fix this so it will work with a axis pluged in?
    Jul 2010
    548
    PG
    check the following error by going to display (F6) Error (F4) this will disply the drive "following" error rate. If the following error does not fall back to below .005 then the control will wait untill it does before continueing on with the next programmed move. This could just be a drive adjustment.
    Call Miltronics tech support. they should help you with the procedure.
    Dec 2007
    118
    BIG THANKS GUYS, Everything working now...(wedge):wave:
  1. Milltronics Centurion 5 450 error Help!
    By Footie11 in forum Milltronics
    Last Post: 11-15-2010, 10:04 PM
  2. milltronics partnerIV centurion V
    By bullitt92 in forum Milltronics
    Last Post: 07-06-2010, 10:51 PM
  3. Milltronics Centurion 4 amp capacitor
    By ozturbo in forum Milltronics
    Last Post: 10-30-2008, 07:06 PM
  4. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
