585,717 active members*
4,048 visitors online*
    Nov 2008
    4
    Cutting closed cell EVA foam
    Hey all,
    I am interested in cutting 5 mm EVA foam....anyone ever attempt this? I have a 30000 RPM spindle mounted to a 4'x4' table. I was wondering if anyone had success in cutting this stuff. I know it can be done but would rather a quick answer than dvelopping a solution for myself. Basically I'm cutting the SeaDek product. Feeds and speeds type of cutter HSS/Carbide etc.
    Thanks in Advance
    Andre
    CUTCNC Guest
    Hello, one of our machine can cut EVA, max 15mm. One of our customer use our machine to produce EVA baseball bat. You can know more about it by below link: EVA foam cutting machine, Or contact me directly. [email protected]
    Mar 2006
    66
    Re: Cutting closed cell EVA foam
    Quote Originally Posted by abeneteau View Post
    Hey all,
    Thanks in Advance
    Andre
    Did you have any luck cutting SeaDek? I want to give it a try and cant find any feeds/speeds etc.
    Dec 2005
    160
    Do a search on you tube cutting seadek
  1. Machining open cell polyurethane upholstery foam
    By DreamsCartesian in forum CNC Tooling
    Last Post: 12-20-2012, 04:07 PM
  2. Cutting XPS foam
    By Mcyoda in forum CNC Wire Foam Cutter Machines
    Last Post: 02-28-2009, 06:33 AM
  3. Anyone CNC route closed cell foam?
    By Nick1983 in forum Material Machining Solutions
    Last Post: 01-26-2009, 07:00 PM
  4. Need help with foam cutting
    By Spitfire in forum CNC Wire Foam Cutter Machines
    Last Post: 09-07-2005, 05:31 PM
  5. CNC Foam cutting HELP!!!
    By Flight in forum CNC Machine Related Electronics
    Last Post: 10-28-2003, 02:24 AM
