585,992 active members*
5,276 visitors online*
Results 1 to 17 of 17
    Sep 2010
    33
    Joes CNC 2006 - Camden, AR
    Well I just completed my second CNC Router. I like many started with a simpler design (JRGO for me) and used it to cut the Joe's 2006. All of the parts were cut on the 15x 30 table of the JRGO before I cannibalized it for the electronics and lead screws. I am very pleased with how it turned out. I am currently getting 200+ IPM without any real tweaks -yet. I also posted a pic of the little JRGO that cut the parts and the bench I build to hold the 2006(I still have to get a buddy over to help move it into place!). I will post some more pics when I get it set in place and start making some chips.
    A Few Specs:
    1/2 - 10 , 5 start screws
    380oz steppers - CNC Router Parts
    5 start nuts - CNC Router Parts
    SuperTech controller (came with Taig Mill, 10 yrs old), 24V PS
    Bosch Colt 1hp VS trim router
    Since this is my first post, I wanted to thank everyone that contributes to this community. All the files/tips/tricks made the build much easier. Finally I'd like to thank Joe for the great design he has generously made available for FREE. You and the JRGO designer have made it super easy for people to get started in the great (and addictive) hobby.
    Biss
    Attached Thumbnails Attached Thumbnails 2011-03-06_15-07-07_678_1208x681.jpg   2011-03-06_15-07-40_809_681x1208.jpg   2011-02-19_13-17-58_985_1208x681.jpg   2011-02-18_16-22-11_835_1208x681.jpg
    Dec 2008
    292
    Biss, nice build, I really like the colors. Makes it look neat and tidy. I still need to paint my 2006, what did you use for primer/paint? Are those galvanized pipe rails?
    Don
    Sep 2010
    33
    Thanks. I used water based paint and primer. I believe the primer was some leftover Kilz and the paint I picked up at the local Wally World. I shot it on with a HVLP paint sprayer (I just thinned the paint with water).
    The rails are just black gas pipe from the local hardware store. I put them on a lathe and sanded them until smooth.
    Thanks again,
    Biss
    Sep 2010
    33
    The router is now in its final home. I installed the home/limit switches and got the homing/limits all set up in Mach3. I constructed some low cost cable carriers out of vinyl window screen trim from Home Depot. They seem to work pretty well, and it keeps the spider web of wires all nice and tidy. See pictures below.
    Biss
    Attached Thumbnails Attached Thumbnails 2011-03-11_10-44-17_741_1208x681.jpg   2011-03-11_10-44-38_708_1208x681.jpg   2011-03-11_10-45-22_608_1208x681.jpg   2011-03-11_10-45-36_190_1208x681.jpg
    Apr 2008
    Nice.
    Out of curiosity, what method did you use to cut the larger parts that don't fit on the bed of the JGRO?
    Sep 2010
    33
    I just cut the longer parts in two pieces. I then just glued them together. The majority of the forces are carried by the top and bottom "skins" of the torsion boxes (much like an I-beam) therefore butting the ends together really results in an insignificant reduction in strength. On the end pieces that are sandwiched together I just staggered where the joint was located. It all seemed to work out pretty well, and things lined up without any real problems. I don't have alot of pictures but i have attached two that show some of the parts. There are actually other ways to do as one piece. You use positioning pins and cut one portion then repositioning and finish the cut. I just took the easy way out, knowing that I would degrade the overall strength very little.
    Biss
    Attached Thumbnails Attached Thumbnails 2011-02-05_13-22-32_143_1208x681.jpg   2011-02-05_13-22-40_286_1208x681.jpg
    Mar 2008
    177
    Nicely done!
    Sep 2010
    33
    g540
    Hey guys. I need some help. I just replaced my supertech controller with a G540. It is powered with a 48V PS (all purchased from Keling) Nothing else has changed (table, motors, software, etc). I think I have everything setup properly, but I am getting random skips or glitches while jogging. I am also getting random faults on the Gecko. I'm not sure what is causing the gecko to just fault, but wen I remove one of the steppers it seems to reduce the frequency of faults. Unfortunately it doesn't matter which stepper I remove, so I don't think its a bad motor. Is there a list of reasons for fault light on the gecko to be triggered (ie no charge pump signal, estop open, etc). I've been screwing with this for two weekends now, and I'm starting to get aggravated. BTW I never had any issues with the supertech controller; it was just alittle under powered. I've tried two different computers (Laptop used with the STech controller before, and an old pc I had laying around). Any ides would be greatly appreciated!
    Keith
    Sep 2010
    33
    cable
    I think I've narrowed it down to a cable from the controller to the z axis. I was able to turn the failure on and off by switching cables...crazy.. I actually don't think it is a faulty cable; it appears to be the type or maybe the length. The cable that goes to my z axis is longer than the others (15'); i guess this could potentially be the problem. its funny i didn't have this problem with the supertech controller? has anyone else had issues with long cables and their g540??
    keith
    Sep 2010
    33
    Update
    Just thought I'd give an update on my Joes 2006. In my last post I described issues with cabeling, etc. I replace all my cables with heavier guage wire and continued to have issues with random skips and "hitches." Well after trying everything I decided to read the Mach 3 instructions on how to optimize the computer. I basically turned everything off that was running in the background and uninstalled a few things. Mach has some tips at the following link http://www.machsupport.com/downloads...timization.txt
    I am using an older laptop with a parallel port and it is working great now. Before the optimization my max speeds were ~175ipm after adjustments I can now reliabily jog at over 500ipm. The stalls, skips, hitches are gone. Anyway I have been enjoying my machine for many months now. I just thought there may be others out there that were like me and doubted the necessity of optomizing ther pc's for Mach (their test program showed no issues either!)
    The Joe's 2006 is a great machine that does nice accurate work. Below are a few pic's of things I've made with it over the past year. Thanks again Joe for the great design and thanks to all the friendly people on this forum.
    Biss
    Attached Thumbnails Attached Thumbnails 2011-09-17_17-03-32_853_1024x577.jpg   2011-09-17_17-03-58_487_1024x577.jpg   2011-09-19_06-57-44_444_1024x577.jpg   2011-09-19_19-47-32_839_1024x667.jpg
    Sep 2010
    33
    More Pic's
    One of these is actually some vinyl work (Thanksgiving plate), but I used my machine to cut the vinyl! It works well for that too!
    Attached Thumbnails Attached Thumbnails 2011-10-27_13-56-58_744_875x768.jpg   2012-01-14_19-00-35_548_1024x577.jpg   DSCN1283_1024x768.jpg   DSCN1286_1024x768.jpg
    Mar 2008
    5
    Good info on computer setup. How's the effort going now?
    I just ordered a "Joe's 2006" kit from Joe. So I'm reading all the old posts and starting to gather all the other items needed to get it going.
    Sep 2010
    33
    The machine is still working great. I'm still using the same setup as described earlier. The gecko g540 is great and seems to be a workhorse. The machine is pretty accurate as well. I just did some engraving in aluminum for a local machine shop. The letters were only 1/4" tall, and they turned out very good. I used a carbide drag bit. I hope you enjoy your machine.
    Aug 2004
    3215
    It good to hear the machine is still working good for you, yes the G540 is a nice plug and play system, many people including myself use it on there 4x4 machines, so the electronics are transferable if people upgrade to a larger machine later on.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Sep 2010
    33
    Thanks Joe, You designed and really nice machine in the 2006. It's amazing how acurate a wooden machine can be. It is really a testimate to the thought you put into this design. If I ever have the need to step up to a larger machine, I will certainly keep your 4x4 on the list.
    For those interested, I attached a few more pics (and a zipped video) of things I have made recently with my 2006.
    Aug 2004
    3215
    Nice I like the Grasshopper kinetic motion.
    All the projects are nice, just curious what the box was.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Sep 2010
    33
    Yeah the grasshopper motion is just amazing to watch.
    The picture of the box is a Cajon drum. It is basically a box you sit on and tap a playing surface with your hand. I built it for a drummer friend for his 60th birthday. To be honest, I didn't use the cnc router a lot for this project but I did cut the hole out and made a pocket for the seat cushion. This was my first time to make one of these and turned out to be a nice sounding drum; especially in the hands of someone that knows how to play it!
  1. Joes CNC Model 2006 R-1
    By joecnc2006 in forum Joes CNC Model 2006
    Last Post: 10-04-2018, 02:06 AM
  2. FLA vs Joes 2006
    By Bear5k in forum DIY CNC Router Table Machines
    Last Post: 05-06-2010, 04:51 PM
  3. has anyone her add diminsions to joes 2006?
    By mufasa75 in forum Joes CNC Model 2006
    Last Post: 03-22-2008, 05:14 PM
  4. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
  5. Joes 2006 Capabilities?
    By a4drvr in forum Joes CNC Model 2006
    Last Post: 10-18-2007, 12:07 AM
