I am researching benchtop mills in preparation for a bike component product line I want to start mfg. I am very interested in the Tormach PCNC 1100 but was wondering if anyone has some information on milling stainless. I need to make some intermittent ~.030" deep cuts on some gear teeth with a 3/4" diameter ballnose carbide cutter. I am basically putting a bevel on these teeth with this cutter. My question is will this mill handle this size cutter and a ~.030" depth cut? I would think it would since it is a very shallow cut but you are all the experts on these machines. Also, I will be doing some engraving with some 1/8" shank, 1/16" diameter tip carbide ballnose cutters with a depth of ~ .003" to ~ .005" deep. Curious if I should be considering the speed attachment to get the ~15k spindle speed? These mills seem quite stout and built quite well from everything I have seen or heard so far. I am looking at the 1100 due to a part requirement of taking advantage of the larger Y axis travel.
Thanks in advance for your input!
Mike
