509,581 active members
4,205 visitors online
Results 1 to 5 of 5
    Registered
    Nov 2005
    3
    Question Supercam gone?
    Any recent development on SuperCam?
    I have an old DOS version that still works, but the computer hardware is getting suspect and I am wondering what kind of upgrade path to take.
    Is there a way to run my Supertech stepper system with another control software? (I'm not sure if there is a 'key' or something that might prevent it from working.)
    Corey
    Registered
    Sep 2010
    33
    You can probably use Mach3. You will need a CAM software to generate the gcode as well. Supercam combines both cam and contoller software. Give Dennis a call and he should be able to help you. He has a configuration file for Mach that makes setup alittle easier.
    Biss
    Registered
    Nov 2005
    3
    Thanks.
    I shot Dennis an e-mail. Haven't heard back. Cruising his super-tech site I noticed that there is no prices or way to order anything...
    Will try and call him this week.
    Registered
    Sep 2010
    33
    The following is a link to the configuration file (bottom right of page, zip file)
    Parallel Port CNC Desktop Taig Micro Mill Complete Three Axis Setup
    Also here's the link to the Mach3 control trial software
    ArtSoft USA - Software Downloads
    I have been using a 10 yr old supertech controller with Mach 3 sucessfully for several months now. He has some other options to get SuperCam to run on newer machines (Xp and newer); it is called a CamPod. You can check that out on his website as well.
    Biss
    Member
    Apr 2019
    Hey guys I know it's been a long while since this has become a topic but I've ran into somee issues. I purchased a KAM plasma table with the Supercamxp software on it and neither of the businesses are still operating..... Can you point me in the direction of some technical support when it comes to software changing using the supercam controller and stepper motors? Any help would be appreciated!
  1. What is SuperCam and SuperCamXp
    By Dennis Bohlke in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2008, 12:47 AM
  2. SuperCam/Taig Need help
    By swartzhund in forum Taig Mills / Lathes
    Last Post: 12-30-2005, 01:43 PM
  3. CNC Taig/SuperCAM Jogging?
    Last Post: 11-04-2005, 02:58 PM
  4. Anybody using Supercam software
    By landart in forum DIY CNC Router Table Machines
    Last Post: 01-27-2004, 09:17 PM
