586,011 active members*
4,693 visitors online*
    Feb 2011
    Alarm 10 - No Signal Y-axis
    I am having a really big problem with my Mazak H-15 powercenter module B with M2 controller coming up with an alarm saying "Alarm 10 - Detect No Signal Y-axis", which doesnt allow me to move anything from the controller. So please if you could give me any help, it would be greatly appreciated.
    I have:
    checked toolchanger's home position,
    replaced resolver for Y axis,
    replaced Y axis servo motor,
    This alarm first came up on startup randomly a few months ago (which we restarted the machine and the alarm would go away), and now is staying on constantly.
    Thanks in advance,
    Paul
    Jun 2008
    150
    The problem could be the encoder cable itself. One of the wires may have parted or broke. Check continuity from the honda end at FX06 through the cannon connector at the encoder.
    If the cable checks out it could be the Y axis circuitry on the FX06 Card itself since you have already shotgunned the encoder.
    I have shaken the powertrac that contains the encoder cable and the wire actually comes back together enough for you to clear the alarm and move the axis to another position. Usually it will trip out around the same spot if you press your luck and try to run without repairing it.
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Fanuc 3M servo alarm overload signal
    By max_c in forum Fanuc
    Last Post: 09-04-2015, 03:23 AM
  3. OMD 086 alarm DR signal Off when recivieing
    By meadowtech in forum Fanuc
    Last Post: 10-25-2013, 09:32 PM
  4. dr signal off alarm
    By driftbuster50 in forum Daewoo/Doosan
    Last Post: 07-23-2010, 07:21 AM
  5. Replies: 1
    Last Post: 10-05-2009, 04:32 PM
