586,009 active members*
4,780 visitors online*
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    Mar 2011
    I try the bob and linistepper with kcam and it works like charm.
    I am so happy now...
    Now i can start with the mechanical part of the project .
  2. #22
    May 2005
    1397
    LOL. So glad it worked out! Congratulations.
  3. #23
    Apr 2007
    1955
    Nice work - I have the kit version from James. Saved me a lot of hassle, but the boards you made are nice too.
  4. #24
    Jun 2011
    lini confusion
    Hi there....Im building my linistepper V2 from scratch but Im a little confused about RN1(the resistor network)...this is my question...Is RN1 different from RN2 & RN3?? it seems from the schematic to be a 5 built in resistors with a common (number 1) pin...unlike RN2 & RN3 in which every two successive pins form a separate resistor...if this is true what is its name exactly so i can buy it cause im not an expert or can i use a set of 5 (3k3) resistors with a commomn pin instead??? need your expert help...thanks alot.
  5. #25
    Mar 2007
    2083
    Hi Simba77eg
    as you have noted RN1 is 5 bussed resistors ,connected to a common terminal
    RN2 and RN3 being isolated resistors
    does this link help
    http://www.farnell.com/datasheets/90452.pdf
    it shows most variations of the resistor networks available
    resistor networks are available in single in line and
    dual in line packages
    the advantage being ease of assembly , space saving and close matching of the resistors in the network
    I can see no reason why you can't use individual resistors in the linistepper circuit
    John
  6. #26
    Oct 2005
    2392
    Individual resistors will be fine if you are building your own.
    We changed to the SIL resistor packs as a service to the user, as they make it much faster and easier to build the Linistepper kit compared to individual resistors, which need colours reading, wire bending, inserting, wire snipping etc etc.
  7. #27
    Jun 2011
    Finally
    Thanks john 100...sorry been away for a while...actually using single resistors is what i did.
    I finished building my linis plus the bob, now I am working on programing the PIC, It is my first time and I am having quit a hard time but i want to learn.
    i will try to post photos for the finished boards.
  8. #28
    May 2005
    1397
    Looks nice simba! If you get tired of trying to program them yourself, pre-programmed PIC's are available for a few dollars US.
    ecomorder.com/techref/ecomprice.asp?p=416060
  9. #29
    Dec 2011
    I need your help
    I made two different versions of linistepper v2 driver. The first was from Murat Shakman and the second from the shematic. Both of them not working.
    If I connect the motor (I tried 2 motors) and power (6volts, 0.8Ampere)to the drivers the motor does not "lock" and of course not move.
    Also I used the "4 axis BOB" from piclist com with the same results.
    I meassured the voltage of A-, A+, B-, B+ points and give me everyone about 6volts.
    I think the problem is at Pic16F628-20IP (it is working on an other project) programming.
    What fuses should be used?
  10. #30
    May 2005
    1397
    The settings are listed in the source code: /Techref/io/stepper/linistep/Lini_asm_v21.asm
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  11. #31
    Dec 2011
    Quote Originally Posted by James Newton View Post
    Thank you sir.
    I didnt set the right settings to the software programmer. Finally I have two working linistepper drivers and I am going to make one more!!!
  12. #32
    Oct 2011
    27
    I knew I shouldn't mess with microcontrollers when I don't know how to program them but now it's too late. I've already built the circuit and I've got the same problem as you... what are those "right settings" ?
    What should I change in that asm before compiling ?
    Quote Originally Posted by spasmenokarabi View Post
    Thank you sir.
  13. #33
    Mar 2011
    10
    Re: Question about Linistepper v2
    That should be fine. Just set the correct device, PIC16F628A, in MPLAB.
    I have try and try but get a lot off errors from mplab, the Lini_asm_v21.asm file is full of bad characters, i have try everything but it do not compile.
    here a piece of it, it looks like the download or copy and paste put in bad characters in the file.
    Attachment 368594
    and here you see strange characters, I can not clean it, it just do not compile and complain, with a new save in utf the errors are less.
    downloading the file is also a problem, then there are a lot of bad characters involved and java is there also.
Name:	ScreenHunter_352 Jul. 24 01.21.jpg
    so strange, I do resume that the asm file fiust compile normal because the board works, maybe the pc here has trouble, these days internet is not that save,
    regards
  14. #34
    May 2005
    1397
    Copy and paste the text from the page into a text editor (e.g. Notepad), NOT a word processor (e.g. Word) and save it.
Page 2 of 2 12
  1. Linistepper v2 problem
    By DjD in forum Open Source Controller Boards
    Last Post: 04-01-2015, 07:51 AM
  2. Question about linistepper schematic
    By DigiSoft in forum CNC Machine Related Electronics
    Last Post: 07-01-2013, 06:40 PM
  3. Linistepper V1 simple question
    By Newuser1 in forum Stepper Motors / Drives
    Last Post: 07-23-2012, 03:11 AM
  4. Linistepper in C
    By hazimin in forum PIC Programing / Design
    Last Post: 01-24-2011, 03:34 AM
  5. Linistepper
    By tante in forum Open Source Controller Boards
    Last Post: 12-19-2005, 04:24 PM
