585,981 active members*
4,310 visitors online*
    Dec 2008
    441
    Red face Can i use the emergency stop like a "slide hold" button?
    Hello.
    I run a fadal 2016L at my work. And the fadal got a button called "Slide Hold".
    Can i fix my emergency stop in mach3 (im using gecko 540) like a "Slide Hold" button so i dont missing any step when i use it?
    Greetings from Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    No. Use the Feedhold instead.
    Dec 2008
    441
    yeah, but the feedhold is not turning "on" before the g code line is finish? so if i run x100mm with a feed 60mm/min. it goes to x100, THEN stop. Understand?
    Try checking "No FRO on Que" in General Config.
    Dec 2008
    441
    Hello again...
    I try that, but it doesn`t change....
    Some other tip?
  1. Mazak T-2 "20 NMI Emergency Stop" Error"
    By Jeff_Y in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 05:35 PM
  2. M2 External Outputs - Feed Hold, Emergency Stop
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 02:49 PM
  3. Where do I install an emergency stop button?
    By alexccmeister in forum Stepper Motors / Drives
    Last Post: 04-22-2007, 12:40 AM
  4. Arcade Button Emergency Stop
    By mikkojay in forum Gecko Drives
    Last Post: 06-07-2006, 06:30 AM
  5. Mach2 bombs when I hit the "stop" button
    By Stuff-Builder in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2005, 04:09 PM
