586,000 active members*
4,953 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Any special tricks to make .dxf files convertable to G-Code?
    Oct 2006
    59
    I have just bought a small three axis router/engraver and am having some difficulties pulling .dxf files into various programs that are supposed to create G-code. When the file is pulled in the programs create no code and some say nothing is found to create code from!
    Here's my scenario:
    - I open ACad 205 and pull in a jpeg.
    - I then create a second layer and make a tracing of an area of the jpeg using the spline tool.
    - I save as a .dxf file
    Do I need to somehow make this second layer a standalone single layer drawing? If so how is that accomplished as I can't delete the layer 0 even after deleting the jpeg from it.
    Mar 2004
    1806
    Justin,
    First off, many cam programs are sensitive to the VERSION of the dxf file. Do your save as dialogue as no later than V14 DXF. I have seen some that even required V12.
    Next, I have seen some that will not handle splines and need regular lines/arcs.
    So you might need to explode the splines to allow execution.
    Also, the cams I am aware of will not recognize "blocks" and need to be exploded.
    Art
    AKA Country Bubba (Older Than Dirt)
    You can't explode splines in AutoCAD to get a usable entity.
    Most .dxf to g-code programs don't allow splines. Saving as a .v12 dxf will convert the splines to polylines, which should get you working. Another option is to download a lisp program to convert splines to polylines, like this.
    Splines to Plines | Cadalyst
    You may want to look at the AutoCAD macro that I wrote to create g-code from within AutoCAD.
    The CNC Woodworker
    Oct 2006
    59
    Thanks to you both. I will save this as a V12 file and see what happens...
    Oct 2006
    59
    That seems to have done it!
  1. IGS FILES AND G CODE
    By vagelism22678 in forum Uncategorised CAM Discussion
    Last Post: 08-17-2011, 10:41 PM
  2. G code and tap files
    By geoff3881 in forum G-Code Programing
    Last Post: 01-01-2011, 02:23 PM
  3. Simple G-code to make, please help ):
    By waxmund in forum G-Code Programing
    Last Post: 10-07-2010, 01:29 PM
  4. 2 g code files
    By Jaby in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-17-2008, 12:02 PM
