585,599 active members*
3,692 visitors online*
    Aug 2008
    1166
    Lost xml file settings after upgrading mach
    I upgraded my mach3 install last week from 3.042.035 to 3.043.022. Started up the new version and cut some parts - no problems. I turned off my computer and it sat for a week (this computer is only for my router - nothing else is on it). Tonight I started it up and all my settings were gone - motor tuning, ports and pins, etc. I tried a backup .xml file from the backup directory, but that didn't work. Then I found an old copy of my .xml file I'd saved from over a year ago. That worked, although I think some of the settings are not where I had them more recently. But why did my .xml file disappear and lose all my settings? That's never happened to me before when I upgraded mach (and it didn't even happen immediately after I upgraded). Any one else have this problem?
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    I had mine get corrupted the other day and had to create a new one from scratch. Mine was due to a PC lockup caused by noise.
    But I've seen others lose there .xml settings, many times over the years. I don't think anyone really knows why it happens.
    What I did this time is make a backup as soon as I had all my settings correct.
    Another option is this program from Klaus, that will make a backup and restore you settings.
    Profile comparison and port pin check
    Aug 2008
    1166
    Thanks Gerry. I'll just go through my settings and try to remember what I had, then make a backup.
  1. Bridgeport Discovery 308 SX-15 CMOS lost time and settings
    By Richardd in forum Bridgeport / Hardinge Mills
    Last Post: 04-21-2016, 02:54 PM
  2. Upgrading to the latest Mach version
    By watsonstudios in forum Mach Software (ArtSoft software)
    Last Post: 06-19-2009, 02:04 PM
  3. Waaah! I lost all of my Mach3 mill settings
    By BrassBuilder in forum Mach Software (ArtSoft software)
    Last Post: 10-28-2008, 01:37 AM
  4. Thinking of upgrading to MACH - What should I expect
    By Hack in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-27-2006, 02:27 AM
  5. Bridgeport Discovery 308 SX-15 CMOS lost time and settings
    By Richardd in forum DNC Problems and Solutions
    Last Post: 06-23-2006, 01:01 AM
