585,712 active members*
3,993 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Axis GUI: How does one turn spindle in reverse??
    Sep 2010
    196
    I can use GCode to get the +10 -10, but shouldn't there be a way to reverse the spindle direction in Axis?
    Torin...
    Nov 2005
    496
    There are manual controls for the spindle in AXIS.
    Though AXIS will hide them if it doesn't find the right HAL pins available.
    Can you post your HAL file?
    Nov 2005
    496
    this is from the manual:
    1.3.5.5 The "Spindle" group
    The buttons on the first row select the direction for the spindle to rotate: Counterclockwise, Stopped, Clockwise. Counterclockwise will only show up if the pin motion.spindle-reverse is in the hal file (it can be net trick-axis motion.spindle-reverse). The buttons on the next row increase or decrease the rotation speed. The checkbox on the third row allows the spindle brake to be engaged or released. Depending on your machine configuration, not all the items in this group may appear. Pressing the spindle start button sets the "S" speed to 1.
    Sep 2010
    196
    Chester,
    Awesome.
    I'm missing the direction signal because my Mesa 7i33 combines speed and direction into a single bipolar output.
    I'll create a trick signal - and what the hell, I have a nice little 24V pnematic solenoid valve that I'll hook up for the spindle brake too.
    Thanks, Chester.
    Torin...
  1. Replies: 0
    Last Post: 02-07-2011, 07:58 PM
  2. reverse taper on quick turn lathe
    By bman356 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-13-2010, 12:20 AM
  3. Please help! Z-axis transistor keeps failing when I turn spindle on
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 03-27-2009, 01:09 PM
  4. reverse on lathe (turn M3 to M4)
    By Igor_UA in forum LinuxCNC (formerly EMC2)
    Last Post: 11-02-2008, 07:57 AM
  5. Ver 7.0 Eztrak 2 axis. Spindle wont turn
    By MrMudd in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:18 PM
