585,973 active members*
4,139 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Homemade Variable Frequency Drive (works)
Results 1 to 9 of 9
    Jun 2010
    178
    Here is a quick video of a VFD we built and just tested. The video shows a 240 volt 3 phase motor being driven at 360RPM. The VFD itself is two modules, the driver board and the logic board. The logic board is powered by a micro controller. Would be more than happy to answer any questions.
    Cheers
    [nomedia="http://www.youtube.com/watch?v=uDg_Az-_Qz0"]YouTube - MVI_2797.AVI[/nomedia]
    Dec 2010
    11
    Hello my friend, what kind of microcontroller you used? Can you make it for 0 to 400 Hz range?
    May 2012
    hi i watched the vid and many others but i would like to actually see how the wiring connects,ie from the motorsetc,,
    Jun 2010
    178
    Quick explanation and pictures
    I've provided some pictures of a few different VFD's we developed. Understand all of these circuits are completely designed, etched, soldered, and then programmed by my friend and I.
    The type of microprocessor we used was an XMEGA. In some pictures you see a typical mosfet based H-Bridge. The final design we used an off-the-shelf IC for the high voltage side. Not much else to tell really, there are a few 24 volt relays, a bridge rectifier, a capacitor, and some fuses. The final design had two boards - the main high voltage switching board and a low voltage microprocessor based control board.
    If anyone has questions I'd be happy to answer, or try my best within reason.
    Attached Thumbnails Attached Thumbnails IMG_2766.jpg   IMG_2772.jpg   IMG_2768.jpg   IMG_2793.jpg
    Apr 2014
    Re: Quick explanation and pictures
    Quote Originally Posted by lukewarm View Post
    Hi there, could please provide me the schematic drawing? thanks
    Nov 2012
    4
    Hello, can You pleas give me the schematics? I want to build a vfd for a saw
    15362
    Re: Homemade Variable Frequency Drive (works)
    lukewarm
    You would be better off buying this from Dmm, & build your VFD with there intelligent Power Module, there is very little needed once you have this power module
    DMM | DIPM Intelligent Power Module | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Mactec54
    Oct 2006
    36
    But why?
    Dec 2019
    I wonder if your VFD has to support Vector control? Thank you.
  1. Variable Frequency Drives?
    By isiahstites in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2010, 07:38 PM
  2. 2 hp variable frequency drive (vfd)
    By valmet58 in forum Bridgeport / Hardinge Mills
    Last Post: 01-24-2010, 04:42 AM
  3. PIC Variable frequency drive
    By xlukkajr in forum PIC Programing / Design
    Last Post: 01-19-2010, 06:27 PM
  4. New Spindle + VFD Variable Frequency Drive
    By automationtechinc in forum News Announcements
    Last Post: 06-16-2009, 04:06 AM
  5. Variable frequency drive for high speed spindle
    By icestation2 in forum CNC Machine Related Electronics
    Last Post: 03-19-2009, 06:20 PM
