584,837 active members*
5,516 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X Editor/MP.dll freezing on startup
    Sep 2009
    104
    When I generate gcode using the G1 button in the operations manager, it automatically opens the Mastercam X Editor. The window opens and the cursor spins for a while, but then it says (Not Responding) in the title bar. The same thing happens if I try to run MP.dll manually. I know this is a very generic question, but is this something anyone has seen before? I can give more specifics if necessary, but I was hoping someone had encountered this before and they knew how to fix it.
    A few quick things:
    Mastercam X5
    all files stored on a local drive
    Windows 7 Ultimate 64bit
    Jun 2005
    305
    Try changing the default editor to Cimco.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Dec 2008
    3110
    It nearly seams that a data path is incorrect,
    or it's trying to post to a folder that is un-available
    ie. you may have changed the name
    Nov 2010
    16
    Im having the same issue... I think its to do with the motherboard, Im running a striker II extreme with a 9800 GX2 PNY GPU
    -Jack
    Sep 2009
    104
    Changing the editor to Cimco worked great. Thanks!
  1. Mastercam Startup Problems
    By Neceda in forum Mastercam
    Last Post: 02-10-2013, 05:59 PM
  2. MasterCam X NC Editor - MCXSTART.EXE
    By jaximus1 in forum Mastercam
    Last Post: 04-22-2011, 12:43 AM
  3. CIMCO V.S. MASTERCAM OR LEGACY EDITOR
    By CNC_BOB in forum Mastercam
    Last Post: 03-12-2010, 02:07 AM
  4. Mastercam X startup error
    By Thinwater in forum Mastercam
    Last Post: 01-12-2009, 09:28 PM
  5. mastercam startup problems
    By sixthearl in forum Mastercam
    Last Post: 01-31-2006, 05:20 PM
