585,567 active members*
3,434 visitors online*
    Feb 2008
    25
    Mazak v 7.5 with mazatrol M2 Will not start.
    After having my machine idle for some time, while I was getting my spindle drive fixed, i tried to start it. When I turn the power On, the damm thing run away on the three axis simultaneously for about 10mm, then it stop with an alarm.
    Any Ideas on what may be the problem?
    The machine was off for about 2 months.
    the reason I had to rebuild the spindle drive was because I had a major short on the drive power supply and the drive cpu went as well. I spent $6000.00 to have it done.
    The machine does not have any alarm to clear , when i turn it on, all axes move in the direction opposite to what they should move to reference it (X axis go positive, y axis go negative, z axis go negative and 4th axis moves anticlockwise.) It then stop and give me alarm 4 servo lag excess 4th axis.
    Vladimir
    Mar 2009
    109
    Sounds like you lost feedback on all axis. Look for something common like a defective feedback card (FX06) or 12v lost to all resolvers.
    Nov 2010
    21
    Quote Originally Posted by Rokkin View Post
    Hi i am also facing same problem but with only y-axis.when in jog i give signal to go for positive it move negative & same in opposite.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Mazatrol M-32 will not start-up
    By Bullet605 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-06-2019, 09:40 AM
  3. Mazatrol T_PLUS no display/no start
    By pocok in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-03-2012, 05:26 PM
  4. Mazak Mazatrol M2
    By sve0019 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-30-2010, 08:40 AM
  5. Mazak H15 with Mazatrol M2
    By Steve_rb in forum DNC Problems and Solutions
    Last Post: 03-19-2004, 01:27 PM
