Originally Posted by
FormX Design
Hmm, its a oooold post, but i give it a try.
Hi, can it, is it possible that a manufacturer has used different type of motors in a machine?
I wondering because i just received a chinese cnc router along with the NCStudio, and when i try to just engrave a square of 100mm x 100mm
the actual square become 100mm x 200mm (approx).
My machine settings in NCStudio is: X=0.003125 Y=0.003125 Z=0.003125
Should i try to set the Y to 0.00625 and leave the other as is ?
Try jogging the axis first and measure how much it moved, if it's moved correctly the amount you specified on each axis, the CAD/CAM software has a setting issue. If it's out the same as when you engraved a square, then yes, halve the relevant axis setting.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
