585,994 active members*
4,600 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 spindle control.
    Feb 2011
    47
    Hi.
    I'll try and post here, since it's the only place I can figure out (if there's a better forum for this question, please point it out so I'll post there instead).
    I'm planning an X3 mill build (Grizzly GO463 to be precise). I'd like to get full spindle control (speed and direction, but I'm not talking about spindle angular position... yet ;-) )
    Someone told me that it's a bad idea to replace the direction switch on an X3 with a relay (the switch's a DPDT switch for spindle current + a SPDT switch for "spindle enable" signal to the spindle control board).
    Is it so much a bad idea to use a relay in this manner? I'd take the VFD output from the G540 to the X3's spindle control board (which I read about on CNCZone), one of the G540's output switch for the spindle ON/OFF switch (through a relay), and the other G540's output switch for the direction relay. I could also use a third relay for the spindle enable switch for more safety, but that'd be redundant with the spindle on/off switch AFAIK. (see the wiring diagram below)
    What do you think? Do I risk frying the G540 (doubtful) or the spindle control board?
    Thanks.
    Mar 2016
    68
    I know it's quite some years old this thread... but did you manage to do it? Did your relays worked well?
  1. G540 Spindle Control Working
    By whitehedr in forum Benchtop Machines
    Last Post: 06-30-2018, 12:51 AM
  2. G540 spindle control problem
    By rewster in forum Benchtop Machines
    Last Post: 12-19-2010, 12:14 AM
  3. G540 Spindle Control for the X3 / Guide
    By Jeff Davis in forum Benchtop Machines
    Last Post: 09-02-2010, 09:53 PM
  4. Is it possible? (G540 spindle control)
    By fretsman in forum Gecko Drives
    Last Post: 10-14-2009, 12:27 AM
  5. Spindle Control Through G540
    By john1285 in forum Gecko Drives
    Last Post: 09-30-2009, 04:26 PM
