585,932 active members*
3,809 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > LVD PPEB 60/15 with MNC 95C control
Results 1 to 7 of 7
    May 2007
    4
    Does anyone out there have any ideas as to what might be causing the pressbrake to "shudder" on the downstroke - no problem during the freefall part but once it passes the mute point it seems like the pressure isn't being maintained. Also the machine won't calibrate the tool in "Production Mode". Any suggestions gratefully received!
    Dec 2007
    32
    Give LVD a call they should be able to troubleshoot it... I was up at their facility last week in Buffalo... Most parts are being made in the usa now...
    May 2007
    4
    Thanks ...
    Thanks for the suggestion .... unfortunately we aren't based in the USA.
    Dec 2007
    32
    Well their also from Belgium so you should be able to call them there also... I don't know why except if maybe you were low on oil possibly... I would check your pressure valves...
    Quote Originally Posted by hassledone View Post
    Dec 2007
    32
    I was at there facility today... They are more then helpful if you give them a call..
    Jul 2012
    Did you change springs on the prefill valves?
    If machine is old, it can be that springs are tired (or broken).
    Better to change both springs on the prefill valves on the old machines. (10 years and more).
    I am sure that your machine will work ok after that a long time.
    [email protected]
    Feb 2009
    21
    Re: LVD PPEB 60/15 with MNC 95C control
    In trumpf v 85 s we had the same problem
    Its propotional valve problem at oure machine and the oil was old roynd 17000 hours
    Chanche new oil new propotional valve and new oil filter
    Machine ok
    Hope you repair yoy machine
  1. Replies: 1
    Last Post: 02-19-2014, 02:19 AM
  2. Replies: 4
    Last Post: 12-20-2012, 06:11 AM
  3. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  4. Replies: 2
    Last Post: 12-28-2007, 04:57 PM
  5. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
