585,660 active members*
3,131 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > How to coat a foam sign
    Feb 2010
    I have a foam sign that i had routed out, and now i am trying to figure out how to apply a coating to it to make it look like a metal sign. Does anyone know how to do this or what to use?
    May 2006
    202
    What kind of foam. If it's HDU I'd suggest using Automotive primer know as catalized High Build Primer. This primer can be sprayed on very thick and will give a very smooth surface. That's what I use on all my HDU.
    Please be more specific when asking questions like this. There are dozens of foams. And the type of routing may also make a difference in priming. If you woul like help, it's here if you give us a chance.
    Joe Crumley
    Norman Sign Company, Norman, Oklahoma, SandBlasted Signs, Sign Painter, Redwood Signs
    Feb 2010
    High Density Foam
    Jun 2005
    10
    Sculpt Nouveau is what you are looking for. Sculpt Nouveau - Patinas and Metal Finishes.
    Here is a link to check out. SignTalkForum.com ; View topic - Fisnishing Signs where Sculpt Nouveau Copper and Tiffany Green Patina were used.
    Andy B.
  1. Sign Foam Board
    By KnotsAboutWood in forum Portfolio Board
    Last Post: 06-20-2015, 07:23 PM
  2. Hard Coat Applicator for EPS
    By TomHay in forum News Announcements
    Last Post: 10-28-2011, 01:12 PM
  3. Sign Foam 3
    By cwells in forum Want To Buy...Need help!
    Last Post: 02-14-2008, 01:51 AM
  4. Where to buy powder coat?
    By Sporqster in forum Mechanical Calculations/Engineering Design
    Last Post: 10-25-2006, 06:24 PM
  5. I'm looking for someone to cut and coat custom foam parts
    By decor designer in forum RFQ Feedback
    Last Post: 08-21-2006, 11:44 PM
