584,861 active members*
4,894 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil in 2011 International Machine Tool EMAQH Argentina, March 25-30,2011
Results 1 to 10 of 10
    Apr 2006
    844
    some pic coming from our dealers in argentina,thank you Mr Peu.
    we show the x7 series with draw bar system.
    Attached Thumbnails Attached Thumbnails IMG_1998.JPG   IMG_2058.JPG   IMGP3429.jpg   IMGP3430.jpg
    Direction,Commitment,Follow through
    May 2005
    925
    Thats me in Green Polo & jeans
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Jun 2007
    394
    I like the look of the X7. Its a beefy looking machine. One question.
    How is it possible to use the flood coolant without it going everywhere around the floor without having an enclosure?
    May 2005
    925
    Beefy it is! a little above 900KG (2000lbs)
    Also changing tools is a breeze.
    A customer welded around the perimeter a metal sheet twice as tall as the current ones around the table, otherwise is a mess as you imagined when using coolant.
    I purchased @ebay a mist unit for testing (accu-lube micro lubricator) it should work much better in the mess dept.
    Jul 2006
    735
    Is there a particular reason not to go with a full enclosure? Even if you are not using flood but just compressed air the chips end up everywhere. And even if you have a only a modest amount of coolant, drilling splashes it all over... and drilling is greatly benefitted by coolant. I have a much smaller machine (sx3/4)and a "full" enclosure that does not have a top (very handy to have the top open like that) but the walls are about 4 feet tall in relation to the table. I have next to zero cleanup, just shovel chips when it comes to that. I would never go back. Just a suggestion
    Then again if you are happy with a large splash guard... well, you saved some
    Jun 2007
    3757
    I just hang a heavy rubber curtain around the head, and use flood coolant without an enclosure. Can't see the job, but who cares. It is automatic.
    Jun 2007
    394
    Quote Originally Posted by PEU View Post
    One of our CNC lathes has a mist system. It is good but I think the flood is better. If the chips build up on the cutter when drilling the coolant doesn't get to the cutting edge. It doesn't use much coolant though in terms of replenishing the tank.
    Does the X7 have a brushless spindle motor, is there any maintenance on the new spindle units?
    May 2008
    666
    I tough we would have seen the V7 model.
    What happened with it?
    Was looking to buy one but changed my mind.
    Not enough info, too dangerous.
    Jeff
    Jun 2007
    394
    Quote Originally Posted by jeffrey001 View Post
    Jeff
    I had forgotten about that. What is going on with Syil Canade now? Are they not reselling the machines now. Do they not own the company?
    May 2008
    666
    This is where Syil should have come on and explain or give more information on their product.
    As usual, no reply.
    This is why I not interested anymore buying a Syil.
    Jeff
  1. 2011 v7 vertical machine center by SyiL
    By syil in forum News Announcements
    Last Post: 01-27-2011, 08:33 AM
  2. 2011 v7 vertical machine center
    By syil in forum Syil Products
    Last Post: 01-23-2011, 03:30 PM
  3. new THC in 2011
    By larryy1022 in forum News Announcements
    Last Post: 01-04-2011, 08:52 AM
  4. Syil Argentina en Fimaqh 2010
    By PEU in forum News Announcements
    Last Post: 09-09-2010, 03:19 AM
