Finally got my first prototype working! And did some successful cuts in wood! :cheers:
I built the prototype as fast as I could, as cheap as possible. Success so far.
My plan is to then build a "proper" one and upgrade components. I'm on a tight budget (like most people I guess) which means compromises.
Ok, here is the current prototype:
[Sorry, I'm from Europe so I design in metric units]
General:
- 3 axis'
- Steppers, 3Nm
- Using cheap-o-threaded rod (I'm amazed how accurate the machine works with them, I thought they would be a lot worse than what they are)
- Wood/aluminium/steel construction
- Spindle: 0.75kW VFD, fully controlled by Mach 3. Motor 3 phase 0.75kW
- ER 25 collet
X-Axis:
- Threaded rod, M10
- "slides" 2 x 1000mm length, travel 500mm (bad I know, compared to the length of the rails, but my DIY ball bearing idea was not rigid enough so I had to make them apart by 450mm)..
- square tubing + bearings for linear slides
Y-Axis:
- Threaded rod, M10
- Slides 2 x 1000mm, fully supported 25mm hardened round shafts
- 4 x 25mm Linear bearings, open type
- travel about 800mm
Z-Axis:
- Threaded rod, M12
- Slides 2 x 500mm, fully supported 25mm hardened round shafts
- travel about 100mm (gantry height not enough to do more)
That's about it in short..
So... here is my "real" machine specs:
- Fully aluminium/steel construction
- X axis 1500mm fully supported 25mm hardened round shafts + 4 x 25mm Linear bearings, open type
- Y axis 1000mm fully supported 25mm hardened round shafts + 4 x 25mm Linear bearings, open type
- Z axis 500mm fully supported 25mm hardened round shafts + 4 x 25mm Linear bearings, open type
- Will still be using the same steppers for now, will upgrade to servos some day
- Ball screws on all axis'
- Rigid enough to mill aluminium with as good accuracy as possible
- A MT3 spindle
I will update this thread when I make progress, but I'm expecting the progress will be slow, since this is only a hobby & I have lots of other things to do as well.
Any advice/help/opinion/anything is appreciated
Added some photos to give some idea of what I have done so far.
