To make a long story short, I due to make a servicing on the z axis servo of my torq-cut 22. As I saw the bad shape of that axis, I decide to swap it with the X axis servo, which I also make a servicing on it due to a bad bearing.
Now all servo in place, wired properly, I started the machine. After the boot, I've engage drives... all seems ok until I tryed to jog the X axis without homing the machine. It does a small move and then, an alarm came on which I don't remember (Im at home) Something like "Drive unable to command BMDC". I've search around the maintenance page and found a command to run a test. In this test all would go well except analog test.
As I saw, both Z and X axis doesn't seems to have their good encoder adresses for the ???DAC???
Here is the question :
Do I have to set the good adresse for each encoders somewhere in the software?
It's just like the DX32 system detect that servo have being swaped.
Anyone have a clue about this?
I'll post more accurate info tomorrow.
Thanks!
