585,763 active members*
4,355 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Help With a DXF to NC Code Conversion
Results 1 to 12 of 12
    Mar 2005
    5
    Hello,
    I have been trying to convert the following to nc code, using a variety of programs downloaded or purchased. G Code 2000, K Cam, Bob Cad, Mach 2, Desk CNC, all are good products, but when I convert the attached DXF, I get the attached NC. When I run this NC code in CNC simulator, or Kcam, I get a mess!!!! My plan is to use the nc code in my DIY cnc router (the part is to be made out of wood). The DXF was made in AutoCAD 2000 by a friend of mine. I am looking for software I can load my DXF into and get nc/g code that will work with a cnc router. Thanks in advance for the help.
    Attached Files Attached Files
    You need to get rid of all the extra stuff in the dxf. All the dimensions, notes, arrows, paperspace layouts. Everything except what you want to cut. If all cuts are the same depth, put everything on a single layer. Only use multiple layers if you need different depths for different lines. And save as R12 .dxf I did all this and used ACE http://www.dakeng.com and it looks fine in NC Plot. See pic.
    Keep in mind that you may need to offset the lines the toolpath radius, depending on the CAM software you're using.
    Feb 2005
    78
    G'day
    I use AutoCad 14 to process the DXF file, then open it in Mastercam 8 to make the nc file. It works fine for me. See my avatar. From a photo in in Adobe Photoshop to Autocad to Mactercam.
    John
    Since he mentioned he has a few inexpensive software packages, I doubt he has $10K for MaterCAM.
    Feb 2005
    78
    270
    Quote Originally Posted by VNSPEC22
    Hello,
    In DeskCNC you right click to control what is selected ( all, region, single, etc). Select just what you want to cut and create your toolpaths, selecting the tools you plan to use, the offset directions, and setting your feeds, speeds, and depths of cut. Use drilling for the small circles, if they are the same size as your router bit.
    The toolpaths will be immediately apparent in DeskCNC, and can be simulated or cut, by switching to "Machine toolpaths".
    Fred Smith - IMService
    http://www.cadcamcadcam.com/hobby
    May 2004
    350
    I think this is what you are wanting I converted it with plasmacam. Tool up is .1000 Depth of cut is .0200 Plunge feed rate 50 cut feed rate is 100
    May 2005
    9
    Hey buddy ,
    Check out this utilty
    http://cnccodegen.sourceforge.net
    Please tell me if it works good for you..
    Regards,
    Vijay
    Aug 2010
    Use this article, and download the converter !!
    Question Re: Help With a DXF to NC Code Conversion
    hello friends! i want to know that how can i convert Dxf file into plasma cutting program. I have Multicam 1000
    Aug 2010
    Quote Originally Posted by techberth View Post
    Use this dxf to nc converter, and download the converter. !!!
    download
    Mar 2016
    60
    The thread looks 11 years old, the guy never answered any of the posts to help him , I expect he gave up or got it sorted
  1. Shopbot code conversion
    By Trainhound in forum Machines running Mach Software
    Last Post: 02-27-2015, 07:01 AM
  2. Question about dxf to g-code conversion
    By Neoathalon in forum DynaTorch
    Last Post: 03-30-2012, 05:59 AM
  3. POW-MIA Image G-Code Conversion
    By rcazwillis in forum G-Code Programing
    Last Post: 05-11-2011, 03:45 PM
  4. CATIA G-code conversion
    By osdhillon in forum G-Code Programing
    Last Post: 06-29-2010, 03:50 PM
  5. G-code conversion
    By jjfab in forum Community Club House
    Last Post: 02-10-2009, 03:29 PM
