585,902 active members*
4,961 visitors online*
Results 1 to 10 of 10
    Apr 2011
    200v Three phase motor 4 poles
    I'm getting 0 ohm from the windings no matter how i measure.
    PE with U or V or W terminals
    or
    between the terminals U, V and W
    Is this the right way to check? If it is, will this mean motor is gone?
    thanks in advance
    24221
    It sounds like you have a ground on the motor, do you have the motor disconnected before measuring?
    Al.
    Albert E.
    Apr 2011
    yes, the motor is disconnected.
    just re-measured again between PE with U or V or W terminals = open cct
    between the terminals U, V and W = 0
    24221
    The winding resistance of a typical 3 phase motor is not going to read alot above 0 ohms.
    There is not alot of point in measuring resistance, it would be more of a concern if you read an open.
    What is the problem you are having?
    Al.
    Albert E.
    Apr 2011
    the problem right now is that the motor is not moving smoothly. kind of jerking move(move, stop, move, stop). that's why I'm guessing one of the winding got short.
    Motor is controlled by a adjustable speed control. Forward and reverse works, but speed does not change.
    24221
    What kind of motor and controller? is this a AC servo motor, when you stated 200v 3 phase motor in your original post I took it it was a standard induction motor?
    Al.
    Albert E.
    Apr 2011
    Motor: Fanuc model 3 AC spindle motor 3 phases 4 poles
    Controller: Leeson AC speed controller
    24221
    Sounds like it could be the controller?
    I would get the motor tested on straight 3 phase to see how it behaves and take current reading of each phase.
    Al.
    Albert E.
    Apr 2011
    you mean connect the motor straight to 3 phase line and measure current between the line and motor? or between the windings?
    If the controller is the problem, you mean the settings on it? or the actual controller?
    I kind of suspect the terminals on the motor might be mislabeled. what is the way to identify which one is U, V or W terminal on the motor?
    24221
    Connect to 3 phase 200v and measure the current on each phase.
    Should not matter between UVW, just that the motor will turn in opposite direction.
    This is providing it is a standard induction motor, which it most likely is.
    Al.
    Albert E.
  1. Can I convert single phase motor to three phase?
    By Jim Estes in forum Phase Converters
    Last Post: 06-04-2020, 02:52 PM
  2. Change a motor from 415v 3 phase to 220v 3 phase
    By Me2 in forum Phase Converters
    Last Post: 06-02-2010, 10:29 PM
  3. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  4. Encoder Poles
    By nate's shop in forum Servo Motors / Drives
    Last Post: 08-09-2008, 03:25 PM
  5. Connect 200V servo motor to 400V drive
    By interflexo in forum Servo Motors / Drives
    Last Post: 04-15-2008, 07:34 PM
