585,749 active members*
3,721 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > WANTED: Light Machines proLIGHT 2000 accessories
    Apr 2011
    4
    I purchased a proLIGHT 2000 a few months ago and have been quite pleased with it. I'm running it from the proprietary software in DOS and would like to outfit it with a light machines 4th axis rotary table.
    I'd like to avoid retrofitting the electronics, so I'm wondering if anyone has or knows where I might find one of these rotary tables.
    I am also looking for the high speed 42k spindle for this machine, or even a 10k motor. Any other original electronics would interest me as well, and lastly, any light machines quick change tool holders.
    Anyone with any of this stuff please PM me and we'll make a deal! Thanks
    Apr 2011
    4
    I'm still looking if anyone can help. Thanks
    Apr 2011
    4
    Re: WANTED: Light Machines proLIGHT 2000 accessories
    Still looking for a 4th axis, primarily. Please PM me if you can help. Thanks!
    Jan 2017
    I I have a bulletin from Light machines corporation that goes in depth on changing your current machine over to the 10000 RPM spindle it's a simple change over of a pulley and belt as well as changing the software to recognize the higher speed. Also you may want to check your baud rate when I got mine it was set on the lower setting I believe is 9600 + The Machine was running at a limp capacity very slow. I will post the info on changing rpm latter.
  1. Prolight / Light Machine TMC 1000
    By ghynes in forum Benchtop Machines
    Last Post: 05-13-2013, 01:43 PM
  2. Trying to get a proLIGHT 2000 up and running
    By voltsandbolts in forum Benchtop Machines
    Last Post: 01-24-2013, 08:47 PM
  3. Need ProLight 2000 ATC Software & Help
    By dcencer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-05-2009, 08:57 AM
  4. Prolight-2000 Manuals
    By toddnv in forum Benchtop Machines
    Last Post: 07-31-2008, 06:16 PM
  5. prolight 2000 atc setup
    By Toyhacker in forum Benchtop Machines
    Last Post: 10-28-2007, 12:01 AM
