585,753 active members*
3,895 visitors online*
    Jan 2011
    depth of cut...
    forgive me if i'm beating a dead horse here but i've searched far and wide to no avail. i'm using Vcarve Pro and mach 3. i'm trying to cut several pockets at various depths. for instance, one pocket is .625. the mach 3 interface indicates that the depth of cut being performed is in fact .625, but is coming out to .125. is this a simple config issue with the z axis or something more? thanks in advance for any assistance.
    May 2009
    435
    It sounds like you don't have Mach set up for your leadscrew. Go to "Motor Tuning and Setup" and change the "Steps per" as required.
    It is this screen here: Motor Tuning and Setup screenshot LINK
    4000 is for a 1/2-10 5-start acme screw, make sure yours is setup correctly.
    Jan 2011
    thats too high of a setting for my machine. i just realized too, that the machine is cutting a mirrored image from what appears on both vcarve and mach 3 interfaces.
  1. Cut Depth
    By mlk1950 in forum DIY CNC Router Table Machines
    Last Post: 03-04-2014, 04:19 PM
  2. Max Cut depth
    By WilliamWoodWork in forum WoodWorking Topics
    Last Post: 10-05-2010, 04:46 PM
  3. x4 Contour and Depth
    By vdauer in forum Mastercam
    Last Post: 01-13-2010, 05:32 PM
  4. What RPM/Depth of cut?
    By sp1nm0nkey in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2007, 04:45 AM
  5. Npt Depth
    By ryanduc in forum MetalWork Discussion
    Last Post: 06-23-2005, 10:24 PM
