To our valued Novakon customers,
We would like to take this time to bring to light the problem we have discovered concerning the current VFD used in our NM-145 & NM-200 mills.
As some are aware, a few VFD’s exhibited low end torque deficiency in a number of machines. Prior to discovering this problem, we did not test for torque, and all machines appeared to work to specifications. In light of reported problems, we have confirmed that some machines did exhibit a problem with the VFD.
In our experience using these machines, we have not exhibited a high failure rate as reported. We are actively working with the motor factory to resolve these issues that appear in the identified machines.
Since we started testing for the lower end torque and reset problems, we have identified in our shop approximately 15% of machines exhibiting this issue. We outlined the problem to the factory and they explained to us that the problem lies in the programming of the on-board processor. They also acknowledge that these symptoms are not exhibited in all VFDs which we have also verified. The problem with the programming created a self-protection shutdown during low speed high load operations. If the VFD experiences an overload condition, the micro-processor improperly shuts down the driver and may no longer be resettable. In this instance, the VFD becomes inoperable. Further testing has been made and was discovered that if the VFD does not initially fail from shutdown then the self protection programming works and the VFD will continue to reset properly.
We have tested in our shop, several overload conditions and the sample VFDs did in fact shutdown. Unfortunately, prior to our realization of the problem through our testing, a number of machines were released to customers that had the issue of the micro-processor overreacting to the fault. We have sufficiently tested and validated that the VFDs in our remaining stock of NM-145 and NM-200 machines are performing properly at present.
Until we understood the magnitude of the problem, we had exhausted our limited inventory of VFDs correcting this issue. The number of spare VFDs was not enough to satisfy all of our customers who experienced the same problem. We have since received additional production VFDs which are available to our remaining customers in solving this matter.
In working closely with the VFD factory on a daily basis, they now indicate that they have isolated the problem and are working on the corrective software programming/hardware. A corrective revision will be released for future VFD production. It is our plan to offer the update to standardize all VFDs to the current production revision which will be provided free of charge in order to bring our customers’ machines up to current configuration standards. The update is significant in reducing our in-house failures that pertain to our warranty with the VFD factory.
It has always been Novakon’s policy and practice to screen and test all machines in our facility against a list of accepted standards within our testing capability before shipment to our customers. As problems are reported via our customer base, we constantly review and update our testing criteria for the most effective screening and acceptance of performance. We believe that this problem should not become an issue in the future.
We would like to assure our customers that since it is our policy to integrate and test our machines in Canada, we can react to these types of problems immediately and effectively. Consequently we do experience longer shipping delays due to the more in-depth testing involved which we believe is warranted since it allows for better testing and control prior to release.
In summary, we wish to express our appreciation for the constructive feedback that has brought this issue to our attention. Rest assured that our efforts are focused in improving the support and technical issues with all of our machines. We are committed to continue and address any problems identified and provide a timely response within our resources. We remain determined to continuously improve the quality and performance of our machines.
Sincerely,
The Novakon Systems Team
