584,817 active members*
5,140 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > projection with v23
Results 1 to 6 of 6
    Aug 2007
    17
    projection with v23
    Is it possible to project an image on a round tapered surface? I tried it with curve projection but not having any luck. It is a surface that starts at about 2inch diameter and tapers down 14 degrees to about a 4 inch diameter. Again, is this possible?
    Aug 2010
    Hello!
    you can project any entities on skins / solids.
    It is not possible to project an image on something.
    But there´s a trick..
    If you have BOBART, create your image in 3D, then use Create Emboss from Solid and select your solidmodel.
    This should "project" your Image on your Model.
    But it´s an stl now...
    This is the only way i see at the moment..
    Grettings from Germany, Tom
    Aug 2007
    17
    Is there any way you can show me an example?
    Dec 2008
    4548
    Here is a video which can show you what he is talking about.
    YouTube - 4th_furniture_redo
    Although, this one is showing using cylindrical stock, the method is the same... Create your tapered surface in CAD, then use that for an emboss from surface or solid, then add an emboss from image after that (There is also a texture one to create different results).
    There will be options with the image one to scale it and move it around on the surface..
    Aug 2008
    121
    As always Burr great work on the the video !
    Rmiller
    Aug 2007
    17
    Got it
    I gave up on the Bobcad and used my Autocad to project it. I didn't think it was possible, but I found a pretty easy way. Thanks for the help
  1. SW2008 curve projection help?
    By duvlitho in forum Solidworks
    Last Post: 10-19-2008, 03:38 PM
  2. Projection
    By fooo in forum Mastercam
    Last Post: 10-17-2007, 03:28 AM
  3. Replies: 8
    Last Post: 06-27-2007, 04:49 PM
  4. Laser Projection Systems, Worth the money?
    By CrashMasterKev in forum Commercial CNC Wood Routers
    Last Post: 02-01-2007, 05:05 PM
