Making a cnc "form relieving lathe" might be most possible with a Galil (or other) motion control system, so long as your spindle motor is also a servo motor. You could write a special routine in Galil commands to accomplish this. The movement would then become a 3 axis interpolated movement.
This differs slightly from a rigid tapping or single point threading, in that both lathe slides and the spindle would move together in electronic cam mode.
But running a normal 3 phase spindle motor as the third axis would not give tight enough spindle control to give good results, IMO.
