585,902 active members*
4,548 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Can anyone recommend a 1.2A stepper motor?
    Oct 2009
    23
    My Sherline conversion has fairly puny motors on it, rather than replace the whole electronics, I'd like to try and just upgrade the motors for now.
    The drivers are 1.2A bipolar half stepping choppers, and the power supply is 40v 10A.
    Does anyone know a good motor that would run on that setup?
    J
    Quote Originally Posted by jonathanm View Post
    J
    Do you need NEMA17 or NEMA23 stepper Motor?
    Check here
    Best Stepper Motor, Stepper Motor Driver,CNC Router, Stepper Motor Power Supply, Stepper Motor Kit,DC Servo Motor
    Oct 2009
    23
    Hi KelingInc,
    I'm looking for Nema 23 size.
    I'd dismissed your motors at first, because I was under the impression that my best bet was to match the current per phase rating as closely as possible to get the most torque per $ with my setup.
    Reading some more, I see the Probotix chart that says if I take a 6 or 8 wire motor and wire it in series bipolar mode, then the current per phase will be the motors rated current x 0.707....
    This would mean that if I find a 6 or 8 wire motor rated at 1.7 amps, and wire it series bipolar, then it will draw 1.2 amps.......does this sound correct?
    In which case it is worth taking a look at your motors again....
    Jonathan
  1. Replies: 2
    Last Post: 01-06-2011, 07:09 PM
  2. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  3. Can someone recommend me a stepper driver with motors
    By purecnc in forum CNC Machine Related Electronics
    Last Post: 02-17-2010, 09:43 PM
  4. Which stepper motor would you recommend?
    By MikeUK in forum Stepper Motors / Drives
    Last Post: 03-08-2007, 02:57 AM
  5. Recommend for Belden or Canare Model cable for 6Amp Step motor ?
    By Calico in forum Stepper Motors / Drives
    Last Post: 07-11-2005, 05:36 AM
