HELLO Les Robbins
THANKS FOR UR REPLY STILL FACING SOME ISSUES,
1-SPINDLE ISSUE .SOME TIME SPINDLE IS WORK OK BUT SOME TIME IT IS DEAD AND AFTER IT THERE ARE ONLY NOISE COME OUT FROM THE MONITER HOUSING (TIK) WHEN I TRY TO RUN THE SPINDLE THRU COMMAND.(IS THERE ANY RELATION BETWEEN SPINDLE AND DOOR LOCK SWITCH ????.DURING THE INVESTGATION I FEEL THAT THE NOISE COME FROM THE DOOR LOCK SWITCH WHEN I TRY TO RUN SPINDLE.
1-chuck clamping un clamping issue...it have pneumatic clamping system.and thru command m78 & m79 the chuck is operating but from pedal no operation .at this time this is the only issue .
THANKS
LOOKING TO YOU
ASIF
