585,762 active members*
4,327 visitors online*
    Apr 2011
    Question Looking for information about CNC's
    Hi All,
    I'm new here but have been interested in CNC for quite a while, I also have interests in Electronics and have been into computer hardware and software for a very long time.
    What I need to know after seeing many forms of CNC, trapezoidal, screw driven, belt driven etc. is which type is the most appropriate for what I want to do?
    I'm after as larger format as possible without breaking the bank.
    Primary tasking: As accurate as possible PCB creation.
    Secondary tasking: Reasonably accurate woodworking using MDF/HDF.
    Tertiary Tasking: Light aluminium
    Primary and secondary tasking are essential.
    Tertiary and the ability to dog food wood be useful.
    And if i could know by both Homebrew and Commercial design types that would be very helpful.
    :idea::idea::idea:
    Jul 2009
    99
    G'day mate,
    not sure if you've checked the huge variety of home-builds on this forum, but I've managed to build the JOES2006 version which has been a really rewarding process and am achieving the accuracy you probably require. Check out my build thread in the link below.
    Also check out Gully's (username Gully) version of the JOES. He has scaled it down a touch and achieved an excellent looking machine.
    From my experience, for a home build, you'll spend at least $1500 by the time you're happy with the thing. Requires you to have access to a half decent workshop to manufacture the parts to the accuracy required.
    Good luck and update this thread with your process.
    - Craig.
    my JOES2006 build thread - http://www.cnczone.com/forums/showthread.php?t=106995
    Apr 2011
    Info required
    Quote Originally Posted by craigjh View Post
    G'day mate,
    Thanks for that, No I hadn't been aware of this machine at all, looks like the size I'm looking for.
    One other question I've got is I've noted that some machines have two motors per axis not one does this help stop skewing? or in some other way help the machine with accuracy?
    Cheers for the response BTW
    Jul 2009
    99
    From what I've seen, 2 motors are sometimes used on the X axis if a wide gantry is used. All depends on how rigid the whole machine has been constructed I guess. I class myself as "not experienced enough" to give you advice on the best way to go, but my particular machine has no issues with the one motor per axis (thanks to a good design by JOE).
    JOES latest 4'x4' table design does use 2 motors for the X axis, due to the wider gantry.
    - Craig.
  1. Bear CNC's new V4
    By wednesday in forum News Announcements
    Last Post: 11-16-2020, 09:39 AM
  2. Replies: 3
    Last Post: 04-14-2011, 02:15 PM
  3. Too many CNC's...how to choose??
    By peter27 in forum Commercial CNC Wood Routers
    Last Post: 03-05-2011, 03:23 PM
  4. WTB - Used CNC's
    By Charlie Gimble in forum Canadian Club House
    Last Post: 10-19-2008, 06:10 PM
  5. Seismic anchoring of CNC's
    By protogregg in forum Uncategorised MetalWorking Machines
    Last Post: 03-11-2008, 05:29 AM
