585,687 active members*
4,856 visitors online*
Results 1 to 6 of 6
    Mar 2011
    Home Anodizing
    Is anyone out there doing any anodizing on aluminum?? I am looking to anodize some aluminum parts I make. Black is the main color but would probably do other colors as well. I would appreciate getting pointed in the right direction.
    Jun 2007
    3757
    Is this the missing link? This might lead you in the right direction...
    Aluminum Anodizing at home - DIY aluminium Anodising
    Apr 2010
    486
    Do a Google search on "anodize aluminum" and you'll find lots of articles. Read several of them, and you'll stumble across the most common errors others have made. Then you can either repeat them, or avoid them, as you desire.
    I think that Ron Newman has one of the original web sites on home anodizing. One thing I saw on his website, or someone elses site was the use of lots of identical coolers, such as Rubbermaid, to hold various chemicals and dyes in his shop. Nice to have a well fitting lid on each cooler, to slow evaporation and keep the odors and gases to a minumum.
    You do need to have a well ventilated shop for this.
    http://www.atmsite.org/contrib/Newman/anodize/
    Tom
    Jun 2007
    3757
    I found that link really good too. Nearly duplicated here.:withstupi
    Apr 2010
    486
    It occurs to me that farm supply stores sell something known as "#9 wire". Suspect that this is a fencing supply.
    But also seem to recall that this is also an aluminum wire. Might be a lot cheaper than buying it at Radio Shack.
    Tom
    Mar 2011
    525
    That looks like aluminum ground wire for antenna installations.
    Quote Originally Posted by TarHeelTom View Post
    Tom
  1. anodizing
    By pyroracing85 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:22 AM
  2. RFQ anodizing
    By bucont in forum Employment Opportunity
    Last Post: 03-22-2007, 08:14 PM
  3. anodizing aluminum at home
    By triump in forum Mass finishing equipment/media/strategies
    Last Post: 11-12-2006, 07:58 PM
  4. Anodizing?
    By Klox in forum MetalWork Discussion
    Last Post: 05-03-2005, 06:46 PM
