585,585 active members*
4,072 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Need wiring diagram of Haas HRT 160 4th axis
    May 2005
    925
    The cable that goes from the control to the 4th axis unit is giving a fault error, I want to test continuity but I don't have the wiring diagram, is not provided in the operator manual, this is the connector:
    I would like to know what goes where from this connector to the square box on the top side of the 4th axis unit.
    Any help will be really appreciated, you know what downtime cost these days...
    Thanks!! :cheers:
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    May 2005
    925
    no one?
    Jan 2011
    rotary connector
    This is a brush rotary table.
    Problems are not in the connector.
    Most frequent failure is breaks in the cable.
    Next most likely is coolant getting into enclosure with motor.
    Knowing the alarm you get helps.
    Pinout at 17 pin connector is:
    L R +5 v
    K R/wh logic gnd
    A Br/wh A
    B y/wh B
    C or/wh Z
    M br /A
    N y /B
    P Or /Z
    T bl overheat sw ref logic gnd
    D bl/wh home sw ref +5/logic gnd
    E & F wh motor +
    J & H bl motor –
    G gr/y earth gnd
    R 115 VAC air solenoid
    S 115 VAC air solenoid
    May 2005
    925
    Thanks a TON !!
    will check the cables and write down the alarm codes.
  1. wiring diagram
    By prabhu58 in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2019, 08:19 AM
  2. HAAS HRT210 wiring diagram
    By jcassidy in forum Haas Visual Quick Code
    Last Post: 03-11-2010, 09:34 AM
  3. 320 ERR/RES wiring diagram
    By schwinndk in forum Gecko Drives
    Last Post: 10-22-2009, 11:33 AM
  4. Wiring diagram
    By jdmyers in forum Bridgeport / Hardinge Mills
    Last Post: 11-03-2008, 11:25 AM
  5. help with wiring diagram for C6 CNC
    By JDsto in forum Syil Products
    Last Post: 01-10-2008, 01:37 AM
