585,970 active members*
4,218 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > building manuel surface grinder and a od grinder
View Poll Results: harbor freight buying...
Voters
35. You may not vote on this poll
  • ok
    10 28.57%
  • as good as dirt
    3 8.57%
  • works for me
    22 62.86%
  • perfect
    0 0%
Results 1 to 9 of 9
    Apr 2011
    any suggestions??? throw them out her i need motovation
    "save nothing" live life like it's your LAST
    Apr 2007
    90
    Interesting proposal, not many diy grinder projects you can take up
    Jan 2010
    485
    How big a surface grinder are you looking at to build?
    Apr 2011
    tiny somthing like 10"x5" (x,y) for simple nothings that go on in the shop i have most of the materials and time so why not and so i can make broaches out of old broken endmills or pisten pins...
    Jan 2010
    485
    Check this out; "Vest Pocket" Grinder The plans are old but can be a good start. Just make sure to make the frame real stout, the stiffer the better
    Some where I might have another set of old plans, if I can find them I'll post them.
    People will laugh/make fun of this type of thing, but back in the day stuff was built at home because no one could afford to buy it. It wasn't that long ago that the thought of a home built CNC was crazy
    Apr 2011
    sweet that is a start i have some good ideas to start but i cant find the motovation to make the z axi right...
    Aug 2010
    I would be interested in a small surface grinder project also.
    Thanks for the idea
    Tim
    Jun 2007
    3757
    My conversion.
    Still collecting parts for this one.
    Now have a variable speed 0-4000 motor on it.
    Needs a ball screw and linear slides on Z. Old screw is hopeless.
    Aug 2004
    780
    Re: building manuel surface grinder and a od grinder
    Fwiw ..
    I am building a CNC T&C machine.
    200x400 mm area, 600 kg steel, 32 mm ballscrews, AC brushless servos.
    Table is a 440x600x100 mm surface plate, granite.
    I have all the main components, finishing lathe refit (new servos, spindle is 2.5 kWservo) and VMC first, both nearly done.
  1. Surface Grinder Help
    By mtparker18 in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2013, 11:41 PM
  2. sunnen grinder lathe attachment or in block grinder?
    By Goldhunter_2 in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2011, 01:42 PM
  3. j&s 540 surface grinder help please
    By MIKE JEFFERS in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2010, 08:18 PM
  4. Surface Grinder
    By itsme in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2006, 06:28 AM
  5. Building CNC Surface grinder - whole lotta questions
    By rashid11 in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2006, 09:53 PM
