Originally Posted by
tasospe
I modify and rename the artcams existing post processor for mach2
And now works fine in mm with mach3 and support tool changing.
Just extract it and put it into the postp folder.
Enjoy
It seems that this post processor has a code that it will go to the home position before running the program.
When i set the fixture offset, i will start from the position it is, and not from the homing position.. Is there a way for that?
I will save some time
Did you use a program to edit the PP ?
Greetings from Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
