585,760 active members*
3,793 visitors online*
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    24220
    I think the decimal is an accidental DOT!
    More like 7A at least.
    Al.
    Albert E.
  2. #22
    Mar 2005
    271
    Hey AL,
    I hate to keep asking you questions but it seems like your the only other member with an Excello 604 cnc mill. I think Im going to start another thread just on my conversion when I get a few more things done. I have started to gut the old control and Im wondering if you used your old power supply.
    I was wondering if I keep everything in the main power panel or not,heres a picture of the inside of the main panel.
  3. #23
    Mar 2005
    271
    Al.
    I think your right.
    Thanks mike
  4. #24
    24220
    See this one in post #3, its sister.
    http://www.cnczone.com/forums/vertic...knee_mill.html
    Yes I used the same power supply and kept what I needed in the panel.
    Mine posts #8 to #12.
    http://www.cnczone.com/forums/camsof...tallation.html
    Al.
    Albert E.
  5. #25
    Mar 2005
    271
    Question
    Does it make a difference what the encoders count per rev is I am looking at buying either us digital e2-1000-315 or e5-1024-236-i-ddd-3 would either of these encoders work well with my servo motors 85volt 7amp and 1700rpm,with a 2 to 1 reduction.
    Thanks Mike
  6. #26
    Mar 2005
    271
    Al.
    Thankyou AL
    Is your excello a 604 the z axis setup looks different,your motor is mounted vertically and mine is horizontal. I find it weird that the motor on mine is like that.
    Thanks Mike
  7. #27
    24220
    Either of those encoder resolutions will work as long as the controller will accept the frequency at the RPM you intend running.
    Al.
    Albert E.
  8. #28
    Mar 2005
    271
    Question
    Al.
    I will be using Mach3, how do I figure out if the controller will accept the frequency at the rpm I will be running?
  9. #29
    24220
    Larken recommend 1000 pulse encoders, so either 1000 or 1024 should work.
    Al.
    Albert E.
  10. #30
    Mar 2005
    271
    Thanks for all your help so far AL,I just sent you a beer I hope you like Alexander Keith's, and Im sure since it seems you are the only one on the forum that can help me out with the excello cnc I will be sending you alot more!!!!!!:cheers:
  11. #31
    24220
    Quote Originally Posted by CATCH22 View Post
    Cheers, I never met a beer I didn't like.:banana:
    Al.
    Albert E.
  12. #32
    Mar 2005
    271
    Question
    Would the AMT102 encoder from KelingInc.net. work with mach3 and my motors,they have a dip switch that can be set to 1000 ppr,do you think these will work?
    Thanks Mike
  13. #33
    Feb 2007
    966
    I would't use those encoders, they don't get any cheaper. Get the US digital E5 or E6 differential if you want reliability, they cost about $20 bucks more per axis.
    I bought a few of the AMT102 from Digikey to try, but wouldn't put them on a production machine.
  14. #34
    Mar 2005
    271
    Smile
    Thanks for the reply Larken,
    Thats all I needed to know,just trying to feel my way through this before I purchase everything I need for this conversion.
    Thanks Mike
Page 2 of 2 12
  1. excello xlo 602 mill help!
    By xlojon in forum Knee Vertical Mills
    Last Post: 12-29-2013, 05:29 AM
  2. Excello Mill
    By Miller Man in forum Linear and Rotary Motion
    Last Post: 02-04-2012, 04:33 AM
  3. Help! Any info for excello 604/605 cnc mill
    By Sparky_NY in forum Knee Vertical Mills
    Last Post: 02-17-2011, 04:51 PM
  4. Excello CNC Mill with Kwik Switch Spindle ATC Options
    By bochek in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2009, 11:44 PM
  5. Upgrading an EXCELLO CNC mill
    By MikeAber in forum Servo Motors / Drives
    Last Post: 04-13-2008, 07:57 PM
