Originally Posted by
Treischl
You can also try Automation 4 Less. Unlike the EBay Store, you can specify the length you need. The problem I had with the EBay Garage sale was the precut lengths resulting in a lot of leftover material. If you pay attention, you will notice that the EBay garage is actually charging you for the cut on the short lengths. Sheesh. As far as I am concerned, if someone charges you for the cut, you should be able to spec the length you want. They also have the connectors, etc.
I got similar garbage from one of the industrial plastic shops near me; went to buy some UHMW to make a spindle mount, $10 for the plastic, $5 just to do one cut on their tablesaw that was close(but more material ofcourse) to the length i wanted. How can they charge for cuts when you're just buying the material? You dont see hardware stores charing you anything to cut rope to the length you want.
A machine is only as accurate as the tools used to build it. "CNC = Computer Numeric Control - or on some days - CNC = Can Not Control" Imagineering
