Originally Posted by
emorning
Hi All,
Last week I finished building my first CNC machine and it cuts more poorly than I expected. When I use the machine to draw with a pen I get perfect results, but it can't cut .25" plywood well at all.
It has a 3'x3' cutting area and is built out of conduit pipes and 1x4's - so I knew not to expect much. Anyway, there are a lot of improvements I can make to this machine (for instance, I could replace the stretchy plastic tubing that I used to connect the stepper motors to the lead screws, I could use iron pipe instead of conduit, my z axis is too far from the z gantry, etc).
However, it occurred to me that an inexpensive position feedback system would be a better way to improve a low-end DIY machine. I'm thinking of some kind of sensor(s) attached to the spindle that can track the relative position of the spindle. Software would then be able to keep the spindle on track.
But first... does anyone know of any such existing feedback system? Or DIY implementations?
Thanks...
-ted
