I am looking for 100 of these parts (see attached) made from oil-hardened drill rod or similar grade steel. It's essentially a basic 2 axis turning job with the acception of the milled flats seen in the drawings below.
The part is approximately 1.5" x 1.5" overall with a 3/4" shaft on one end. The 3/4" shaft is the only critical dimension and I would prefer a .0005"+/- tolerance but .001" would be acceptable. Separate quotes for each is fine. ETA is flexible but would like to award job by the 15th.
If you have any questions or requests for more information then let me know. Thanks!
