Hi all,
I purchased some sheet material of what I thought was HDPE (or PE) off EBAY (from a local shop re-fit). Turns out it's not what I thought it was, but I'm not sure what it is!!! Was advetised as perspex, I had asked was it like "chopping board" type material and the response was yes. Anyway I have it now so would like to know what I've got!
I intially suspected it may be fibre-glass, but have nil experience with fibre-glass other than knowing it's hazedous to cut.
It drills quite easy and I even tapped a thread through it. Is it FG? Or just hard plastic? Maybe it is perspex. but I thought perspex was more brittle. One sheet of aprox 1200x1500x20mm is almost a 2 man lift. Heavy stuff. I have 4 sheets of that size and 3 of a thinner (aprox 12mm) size. The thinner sheets are quite bowed, which I also didn't think FG would do?
I've attached some photos hoping one of you could help me out. I'm sure it'll be easy for someone.!.
-Craig.
