Z wont retract
hi, simple problem
the 'z' axis wont retact after this pocketing opp.
was written with VQC, but karnt see that as a problem
T10 M06
G00 G90 G55 X60.017 Y19.991
G43 H10 Z35. M08
S2500 M03
G01 Z0 F1000.
G13 G91 Z-0.5 I2.001 K4.05 Q0.1 L12 D10 F100.
G00 Z35. M09
M05
G28 G91 Z0
G90
M30
basically it's just a bolt head hole
using a 4mm endmill, 4mm pilot hole, offsets set properly
it pockets with no problems, then returns to center and just sits there
F250. has the same problem
but if i increase the feed to F500. , it retracts fine
any ideas?
:cheers:
HAAS TM-2
Mastercam X4/X5 - Level 3 - Solids @ work / HLE @ home
