510,035 active members
2,899 visitors online
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > DynaTorch > dynatorch set up for duct work thin ga
    Registered
    Apr 2011
    5
    anyone have a good set up for cutting duct thin galvy 24 ,26 ga. amps, ipm, sp, etc. also could use some help with vertex slowdown, i run mine at 50/50 but dont really understand the exact mechanics of it of it.
    Registered
    Dec 2007
    41
    The settings I use for ductwork are arc voltage 85 and speed 200ipm. I'm using a powermax 1000 with finecut consumables with the plasma set at 30amps. These setting are best for 26g to 20g sheetmetal. Running great for about 4 yrs.
    Registered
    Apr 2011
    5
    cant seem to get up to 200ipm, anything after 180 the corners get sloppy like it cant handle the speed and you hear the gantry banging a bit. I think the corner slowdown is not set right, have it 50degree/65% with acceleration at 6.
  1. DIN 3 Rail & Wire Duct Screw Sizes??
    By jevs in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2011, 03:35 AM
  2. Is Dynatorch a good choice for mass production work?
    By Homer Simpson in forum DynaTorch
    Last Post: 11-05-2010, 02:49 AM
  3. 4x4 dynatorch available
    By redfarm in forum DynaTorch
    Last Post: 08-10-2010, 12:14 AM
  4. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum General Metalwork Discussion
    Last Post: 06-07-2010, 07:22 PM
  5. CNC for a/c duct liner
    By WMACS in forum Open Source CNC Machine Designs
    Last Post: 10-02-2007, 07:18 PM
