585,712 active members*
4,038 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Cutting chamfers and fillets?
Results 1 to 14 of 14
    Mar 2009
    30
    Hi All,
    I am just starting out with Mastercam X5 for solidworks. I have been able to get mastercam to produce a tool path for flat surfaces and for pockets, but I cant understand how to produce a tool path for a fillet or a chamfer.
    I have created a solid square box in solidworks and put a chamfer on each of the four top edges, very simple. I can get Mastercam to mill off the excess material from my stock setup, but for the life of me I cant make a tool path for the fillets.
    Please can someone point me in the correct direction. I am pulling my hair out after 3 days.
    Simon
    Dec 2008
    717
    Most of the time fillets follow contours, so just use the contour (edges) and create your tool with a corner radius. (2d contour with a ballnose/bullnose endmill - it's that easy)
    Chamfers - use the same contours (edges) as the main wall, use 2d contour toolpath like above, then select 2d chamfer and define the size of chamfer you want - create a spot drill/chamfermill type of tool and you are done.
    Post a model or file and I can help if you need.
    Tim
    Mar 2009
    30
    Hi Tim,
    Thanks for getting back. Not quite sure how to put your answer into action. I tried to select a ball nose tool and a 2D contour but I still dont get what I am expecting.
    I have attached a JPG of the type of cuts I am trying to make, if you are able to provide any help it would be very much appreciated.
    Simon
    Mar 2010
    SELECT CREATE SURFACE FROM SOLID , SELECT THE SOLID , ENTER,
    SELECT TOOLPATHS SURFACE FINISH ,SELECT RADIUS SURFACE YOU JUST CREATED SELECT FLOW FROM BOTTOM TO TOP ADJUST PARAMETERS UNTIL U LIKE IT ..
    Mar 2009
    30
    Sorry to be so Dim, but when you say create surface from Solid, are you in Mastercam at that point or Solidworks. I dont see a Create surface from Solid menu option in either the Mastercam menu or in Solidworks menus.
    Just so we are singing from the same sheet, I am using MasterCam X 5 for Solidworks.
    Dec 2008
    717
    Sorry - by fillet I thought you meant an inside radius. For an outside radius, that you don't want to use a corner rounding endmill for, use a surfacing toolpath with a ball with a tight stepover (.010-.020") (depending on how smooth you want the surface.) I would use a cornerrounder if you can, though - if it is a normal fraction/size since it will save you incredible amounts of time over surfacing.
    For surfacing, you need to select the "Faces" that are rounded for the main drive surfaces and select the top face as a face to avoid (under the "check" section). I don't think you need to create surfaces from solids - at least you don't in the "regular" mastercam. You are free to just select the faces.
    If I have a few minutes here I will get you a quick file - I assume that Solidworks X5 will open a regular X5 part...?
    Tim
    Mar 2009
    30
    Thanks Tim, What do they say, a picture speaks a thousand words. A file to look at would be really helpful.
    Your a star
    Simon
    Dec 2008
    717
    Simon,
    This is just a simple surface parallel toolpath. Different surfacing toolpaths follow the material differently, (That sounds obvious enough...lol) so experiment with them to see what they do.
    Chamfers are much simpler as they are just 2d contours with 2d chamfer selected.
    Attached Files Attached Files
    Tim
    Jul 2013
    84
    maybe this is the wrong area, But I am assuming a 3ax mill would have no issue milling a fillet. Is there a specific cutting tool used or a flat cut tool wih a suitbale tool path do the trick..
    PS having some issue with cam-works for a very simple fillet!
    Dec 2008
    717
    Quote Originally Posted by itolond View Post
    Well, first off you are correct. This IS the wrong area. This is the Mastercam forum not the crapworks..er camworks forum.
    Maybe search here: CamWorks to see if there is a similar string or post a new string regarding your question. I'd attach a picture of what you are after but on first guess I'd say that a square endmill is not the ideal tool to profile or surface a fillet.
    Tim
    Apr 2003
    3578
    Can you give me your file I will add the fillet paths in Mastercam 4 solid works.
    Cadcam
    Jul 2013
    84
    Hi and thanks for the offer.
    I would like to get to the bottom of this, I did change to a chamfer with the same result.....go figure
    Re: Cutting chamfers and fillets?
    thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaank yooooooooooooooooooooooooooooooooou! WallyZ for actually posting a mcx file so I could see a example. it really help out my friend!
    Apr 2003
    3578
    Sorry to say if you want a cleaner surface all the way around and not all that jumping use Flowline or surface contour.
    Cadcam
  1. Cutting big chamfers..?
    By TiagoSantos in forum Benchtop Machines
    Last Post: 04-12-2013, 06:49 AM
  2. Need an assist on chamfers...
    By gogego in forum G-Code Programing
    Last Post: 08-06-2011, 07:39 AM
  3. Can you pattern fillets?
    By bigalexe in forum Solidworks
    Last Post: 04-28-2010, 03:40 PM
  4. Naked Edges on Fillets and Chamfers in Rhino
    By spincaster in forum Rhino 3D
    Last Post: 04-05-2010, 11:05 AM
  5. Fillets out of no where?
    By star1280 in forum BobCad-Cam
    Last Post: 11-20-2006, 07:00 PM
