584,829 active members*
4,906 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > post modification help
    Sep 2006
    39
    I have a customer with an SCMI router. BC gave them a KerrXlog3 post and it does not seem to generate the correct Gcode. BC is telling me it will take two weeks to review my post request. One of the guys at BC showed me how to modify a post by changing the file extension and opening up in wordpad...I think??? Does anyone know how to do this? I can send a sample of a working file and one that does not work if you need
    Jun 2008
    1838
    What version of BC ? V23 ?
    Zip up the Post, the good code and the bad code and someone will take a look at it for you.
    Don`t usually have to change the Post file extension to open with Notepad etc as far as I know ? ?
    Regards
    Rob
    :rainfro::rainfro::rainfro:
    Sep 2006
    39
    sorry about that, I am running V21...I know it is easy to change posts in V24.
    "Zip up the Post, the good code and the bad code and someone will take a look at it for you."....you mean at Bobcad? I would like to impress the customer and 2 weeks will not make a good impression. If I can make the changes myself and get this job going for them in the next couple days, I might have a job there.
    Feb 2009
    2143
    Put your posts up in this thread so someone on here can help you out directly. You may get it done today, but not without the files loaded here so we can see what works and what doesn't...
    Sep 2006
    39
    sample code.
    This is a sample of the bad Gcode, below that is the good Gcode:
    H DX=10 DY=10 DZ=10 -A C=0 T=0 R=1 *IN /"DEF" BX=1 BY=1 BZ=1
    C=0 E=2# S=15000#
    G0 Z=0 T=101
    G0 Z=0.2 E=2#
    G0 X=1.5 Y=2.4 E=2#
    G1 Z=-0.25 V=5.
    C=2
    G3 X=0.9 Y=3. I=0.9 J=2.4 K=-0.25 V=10.
    G1 X=-1.44
    G3 X=-1.5 Y=2.94 I=-1.44 J=2.94
    G1 Y=-2.94
    G3 X=-1.
    G1 Y=-2.94
    G3 X=-1.44 Y=-3. I=-1.44 J=-2.94
    G1 X=1.44
    G3 X=1.5 Y=-2.94 I=1.44 J=-2.94
    G1 Y=2.4
    C=0
    G1 Z=-1. V=5.
    C=2
    G3 X=0.9 Y=3. I=0.9 J=2.4 K=-1. V=10.
    G1 X=-1.44
    G1 Y=-2.94
    G1 X=1.44
    G1 Y=2.4
    C=0
    G0 Z=0.2 E=2#
    N X=0. Y=0.
    This is the good Gcode created in a program called Microvellum:
    H DX=97.00000 DY=49.00000 DZ=0.75000 -AD R=1 *IN /"DEF" BX=0 BY=0 BZ=2 V=11
    ; Microvellum Post
    SET ZFAST=.25
    F1
    BO X=4.50625 Y=29.6875 Z=0.75000 V=4 D=0.18504 N="P"
    BO X=10.475 Y=29.6875 Z=0.75000 V=4 D=0.18504 N="P"
    BO X=16.44375 Y=29.6875 Z=0.75000 V=4 D=0.18504 N="P"X=18.95375 Y=29.31250 Z=0.12500 S=18000 T=101 E=1#
    G1 X=1.99625 Y=29.31250 F=28.00000
    C=1
    G0 X=19.12125 Y=29.31250 Z=0.12500 S=18000 T=101 E=1#
    G1 X=36.07875 Y=29.31250 F=28.00000
    C=1
    G0 X=36.07875 Y=30.07813 Z=0.12500 S=18000 T=101 E=1#
    G1 X=19.12125 Y=30.07813 F=28.00000
    C=2
    G0 X=27.67003 Y=36.36523 Z=0.76000 S=18000 T=101 E=1#
    G2 X=28.17421 Y=36.71187 F=28.00000 I=27.72090 J=36.83121 ;R=0.46875
    G1 X=30.08522 Y=43.97042 F=28.00000
    G2 X=29.69486 Y=44.55427 I=29.63192 J=44.08977 ;R=0.46875
    G2 X=18.05514 Y=44.55427 I=23.87500 J=1.60302 ;R=43.34375
    G2 X=17.66478 Y=43.97042 I=18.11808 J=44.08977 ;R=0.46875
    G1 X=19.57579 Y=36.71187
    G2 X=20.07997 Y=36.36523 I=20.02910 J=36.83121 ;R=0.46875
    G3 X=27.67003 Y=36.36523 I=23.87500 J=1.60302 ;R=34.96875
    G1 X=95.88125 Y=26.43750
    G1 X=83.94375 Y=26.43750
    G1 X=82.94375 Y=26.43750
    N X=0.0 Y=0.0
  1. Post modification
    By westerfieldcct in forum BobCad-Cam
    Last Post: 12-11-2010, 05:28 PM
  2. V8 Post Modification?
    By mjp in forum Post Processors for MC
    Last Post: 01-05-2009, 12:30 PM
  3. Post modification help?
    By bassn_07 in forum Esprit
    Last Post: 06-16-2008, 08:56 AM
  4. post modification
    By valmet58 in forum Post Processors for MC
    Last Post: 05-15-2008, 02:46 AM
