Jim I hope your out there....? I am trying to cut a tapered die opening.My u/v axis is moving incorectly . The taper should be big on the bottom small on the top....When it read the line with G52..t 1.0 ..the u/v cut a big taper on the top and a small taper on the bottom. When it gets to the line with G02....it cuts okay....The problem is the wire is clipping the top hole making a strange looking oval..It looks like two tapered holes inside each other one small and one large....like it is trying to cut a G52/ G51...In the same hole even though I only call one taper command.....On my taper settings page I use 1 for taper settings...It will graph correct . But cuts wrong......Please help Jim this is Gabe from Houston The modle O. That had all the cut wires inside the control cabinet.....Thanks.........
