585,560 active members*
3,160 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Geometry Editor Drilling
    Jul 2006
    367
    Hello, I've been searching, but , can't seem to find a how to. I'm slowly learning how to use this software, but, the manuals are kinda limited. How do you add drilling after making a part in Geo editor.
    I have the contouring down, but, can't seem to figure out how to drill a hole. Do you have to edit the G code after post processing????
    thanks
    pete
    May 2007
    428
    Pete,
    1) Create a Pattern of Points to be drilled.
    This can be done in the CAD module by selecting the Pattern option of the contour creation dialogue.
    Patterns can be created in CAM by using the Pattern feature (found under machining menu item)
    Patterns can be created from circles found on imported DXF files.
    2) Within the CAM module :-
    Define a Drilling Tool
    Select Tool Change Operation (M06) and set Current Tool to a Drill Tool.
    Select Drill operation and set drill cycle parameters.
    Example files attached.
    2 Patterns, one created in CAD module and one created in CAM module.
    Two tools defined.
    Files attached.
    Attached Files Attached Files
    Dolphin CAD/CAM Support
  1. 2d cad editor
    By 071203 in forum OpenSource Software
    Last Post: 09-25-2009, 02:22 PM
  2. Spot Drilling/Center Drilling Steel 55 HRC
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 03-11-2009, 07:35 PM
  3. MC X Editor
    By cijunet in forum Mastercam
    Last Post: 02-21-2008, 05:28 PM
  4. drilling and drilling cycles tutorial
    By wmorre in forum MetalWork Discussion
    Last Post: 10-19-2006, 12:30 AM
  5. Editor
    By Okuma_ray in forum Uncategorised CAM Discussion
    Last Post: 01-07-2004, 02:30 PM
