Hey there guys, I just picked up a 1986 Victor VMC Vcenter-4 with Fanuc 10m control. When I powered up the machine and had the airlines hooked up, the tool pod immediatly went into the down position. It stayed there for a couple days while trying to troubleshoot it and figure it out. Today when I powered the machine down at the head, the pod magicly went up and stayed there. OK great! So I powered back up and went into MDI mode and typed in T2EOB and ran it. The carosoul selected the proper tool. I then typed in M6EOB and ran that. The tool changer performed the tool change until on its way back to complete the change over I made the mistake of leaving a gard loose and the arm errored out and halted because of the contact. I then bolted the gard back up in place but now I cant clear the error light on the control panel. The pod is also now stuck in the down position again. Does anyone know what I should be doing to clear the error or any way to bring the tool pod back into the up position?
Thanks in advance for any help!
