So I'm in the middle of a fairly important project and need help ASAP!
My Syil SX3 has started showing weird issues. The x axis just sounds bad whenever moving (like grinding - I oiled it but it didn't help). Also, it's very hard to move manually by spinning the motor by hand when the mill is off and sort of springs back a few steps when let go. I've ignored the issue for a couple days, but I just found out it doesn't seem to be cutting right.
Here's an example of a circle it tried to cut using G-code that I know has worked before:
http://img64.imageshack.us/img64/4686/img8096i.jpg
It came out like something between an oval and a rectangle with rounded edges...
Any ideas/tips?
It's been oiled and cleaned and I glanced at the wires to look for anything obvious falling out, but didn't really take stuff apart to look for issues yet...
Thanks in advance
