585,597 active members*
3,545 visitors online*
    May 2011
    Thread Milling
    How do I go about creating a thread mill in X5? Ive never done thread milling in a cam software.
    Nov 2006
    418
    Go to Toolpath>Circular Toolpath>Thread Mill... You can use a point to locate the threads and define the thread diameter in the settings windows or you can use a circle to locate the threads and the diameter of the circle will define the threads - meaning it should be the major diameter of your thread if it's an ID thread or minor if OD. You'll need to set the thread pitch, depth of threads, # of teeth on the threadmill (so Mcam can know whether one loop will complete it or it needs to do multiple loops), and so on.
    I like to use two passes and wear comp. I find that it doesn't take much to convince me to thread mill over tapping larger holes now days, it's so much easier to control.
    May 2011
    Quote Originally Posted by John_B View Post
    Thanks. I mainly need to know how to create the tool itself though. I don't see one listed
    Nov 2006
    418
    Ok, use a seperate level and draw half the profile of the tool on the X+ Y+ quadrant, going up Y+. Then use define custom tool and check to use a level and pick your level you drew your tool on.
    You can also copy one of the existing tool files and rename it for your threadmill and use it as a basis to start from (there is some more info in the help files) to create a tool file that you can save. This is what I've done for the 10 or so different threadmills I use.
    Apr 2003
    3578
    Also you can also just use for example a 1/2 EM if you hop is that size for example.
    But if you draw the tool with the active teeth you will see the threads in Verify.
    Cadcam
  1. Thread milling with x z c
    By murrayclair in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-16-2011, 03:03 PM
  2. thread milling
    By rylanrouge in forum Uncategorised MetalWorking Machines
    Last Post: 10-13-2010, 05:54 PM
  3. thread milling V21
    By AirChunk in forum BobCad-Cam
    Last Post: 09-15-2010, 06:12 AM
  4. npt thread milling help
    By MIKEPETTY in forum Haas Mills
    Last Post: 07-19-2010, 06:05 PM
  5. Thread milling
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 12-01-2007, 04:01 AM
