585,951 active members*
4,254 visitors online*
Thread: Chip Load
    May 2011
    Chip Load
    How much do you increase your chip load from manufacture recommend when using a trochoidal tool path. According to SGS website it appears to me that their recommended chip load is based on 50% step over.
    Dec 2004
    44
    Can you direct me where you found it
    May 2011
    Quote Originally Posted by ak762 View Post
    SGS home page then to the high performace section. Each type of endmill is listed and there is a speeds and feeds pdf with each. If they figure the chip load at 40 or 50 percent step over can I increase proportionally as my step over decreases? Like can I run 4-5 times faster feed rates if Im only stepping over 10 percent in a trochoidal tool path?
    Apr 2003
    3578
    I suggest about 20 to 30% matters on tool and what material you are cutting.
    Cadcam
  1. SFM vs Chip Load
    By strohkirchw in forum Benchtop Machines
    Last Post: 12-11-2010, 02:43 PM
  2. PVC chip load?
    By rigo430 in forum Material Machining Solutions
    Last Post: 07-17-2010, 08:05 PM
  3. Chip load & speed /feed info
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 03-10-2009, 02:44 AM
  4. Chip load and cutting depth.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 07-19-2006, 08:24 PM
  5. chip load question
    By cncsdr in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2004, 02:08 PM
